Re: CopyCad plating on 62 sq. in. object
Hi Dave:
We don\'t take support requests on this board. We\'ve set up an online support system for you to use, which allows us to solve problems more efficiently.
If you click the \"Need Support?\" link below, you\'ll be taken to our support site, where you can use our PRS system to log your problem. A support tech will post a solution shortly after that.
Thanks!
