Black Dye problems/Smears and Streaks
Finally, my real job is slowing down a bit and I can get back to anodizing...I just mixed up a fresh batch of black dye and tried it last night. The parts came came out with a reddish bronze look to them with out the slightest hint of black (See black die problem pics in the anodizing album.) The parts appeared to be taking die well in the run but after two minutes in my drying cabinet the black die vanished. Parameters are as follows: 4.5 amps/sq "...73* I hit par at 71 minutes. The Die tank was at 120* for 25 minutes.
I had another piece in the run that was polished rather than bead blasted, it had some different problems.... I died it light blue on the rear of the body to clear on the front. Along the whole body it seemed to have faint streaks, spots, and smudged areas on it (See smears and streaks pics in the anodizing album.)
As I mentioned my chemicals have been covered dormant for about three months, my job is very seasonal. All my tanks have lids on them and are in a clean environment.
Thanks for the help,
Easttex
