Yes it may vary the results but not enough to really effect anything. Powder just needs to hit a temp between 300 and 450 your reading won't be off by 15 degrees probably. Also do you wish to probe that fresh coat of flowing powder to check it?So yes he is correct, however you aren't trying to hold a 2 degree tolerance.The main thing is that you bake consistantly.
