Thread: IR Temp Probes
Old 07-21-2004, 10:12 AM
getastro's Avatar
getastro getastro is offline
getastro
When I used the IR device to read temps I was getting the wrong temp reading. For example I just did a swing-arm, it was in the oven for close to an hour. I used the IR to read the part temp looking for the curing time to start, but the top of the swing-arm read 375 and about two inches next to the first reading was only 325. So I went in search of a better way to get part temp readings. Just wanted to let other people no the you can get close with the IR, but if you looking into correct readings get something else. That’s all
