Old 07-25-2004, 09:26 AM
rotorman rotorman is offline
rotorman
Default problems polishing aluminium alloy with white compound
hi all,
I think i've achieved a pretty good standard for alloys now up to the tripoli stage. when I get to white compound things go wrong - I'll fill you in on my technique in detail, and hppefullly this will reveal my mistake.
I go the tripoli compound on a loose leaf calico mop. I find the stitched cotton mop removes material too quickly on this particular alloy.
Then I use white compound on loose leaf calico mop. I just bought a new mop, as I didn't want to cross contaminate my compounds.
I am using a 3000rpm bench grinder. The mop are 6"x1".
Now, here's the problem. With the tripoli stage almost mirror with some light buff marks, I move to the white compound.
I have found that with larger flat surfaces, like radiator tops, and in this case, a throttle body, the white compound breaks down (?) on the surface and leaves hazing. the hazing sometimes also has small pit marks where spots of compound have stuck to the surface. the hazing is strong enough that going back to tripoli takes a while to get it out...i don't think the talc trick will be enough to remove the marks?
small areas do not appear to have this problem and are chrome like in finish.
I use a fine hacksaw blade to clean the buff. I try not to overload the buff with compound. I try to apply load to the buff when applying compound so that it has some heat and is applied evenly.
the buildup seems to happen whether i am using a colour stroke or a cut stroke, but appears to be worse with the colour stroke?
What could I be doing wrong?
is it...
(1) the brand of the compound?
(2) technique?
(3) contamination on the surface of the piece (I use mineral turpentine to clean followed by warm water after each polishing stage)
(4) insufficient heat?
Is white compound meant to be used with a colour stroke only, or cut only, or both?
Please advise...any help is much appreciated. I'm getting very close to results I'll be happy with.
