Old 07-27-2004, 08:24 PM
clab clab is offline
clab
Default Strip the tin first
I got not so good results going over the tin/solder plate on my pcbs. I tried a number of strip methods (mechanical) and none really worked well enough. I found that nitric acid diluted with a bit of 12% hydrogen peroxide applied with a Q tip worked well for this. Then nickel, then gold, and it's as good as the pros can do it.
