Old 08-08-2004, 02:20 PM
Sid03 Sid03 is offline
Sid03
Default input on aluminum polishing and need help choosing a buffer
Just wanted to see what you guys recommended......
Currently using a bench grinder I converted over to buff with(removed shrouds, added axle extenders and went from 6" to 8" wheels). Im really not sure of the motors HP, but its a Delta bench grinder from Lowes......110V, 2.5A 3450RPM......if that helps at all. I can load it down fairly easily which I think is slowing down my polishing jobs greatly. I only polish aluminum....usually 6000 and 2000 series. What do you guys recommend. Do you think the caswell 1/3 HP would be a step up or not? Should I just got fo the 3/4HP?
Now on to actual polishing questions. What do you recommend for the above mentioned alloys(2000 and 6000 series aluminum)? I am polishing heavily detailed milled parts. I start with the aluminum cut and color compound from caswells on a spiral sewn cotton wheel, and finish with the same compound on an untreated vented buff wheel(it seems to remove any heat marks). The wheels have both been used for a fair amount of time.....should they be replaced every so often(I do rake them). The spiral sewn wheel works decent, but takes awhile to get the job done. I have tried sisal before and it was alittle too rough and couldnt get into some of the milled pockets on the parts. You guys think a new buffer would do the trick, or should I switch to a different compound or different wheels? Thanks for any input!
