I am getting good results. But am I doing it right?
Quick question for the gurus. I am using a basic anodizing kit and 20 amp battery charger. I am getting good results, but something puzzles me. I have a clamp on amp meter for dc current. When I turn on the anodizing process I can spike the amperage up high but it comes down very quickly. Typically what I do is turn it up just above where it usually stays. Since the amperage always comes down quickly to this point anyway spiking it does not seem to be a good idea. The question is why does the amperage want to stay in a certain spot and no higher? After awhile of anodizing the amperage may even go up slightly, but sooner or later it starts to drop and I usually cut it off after it has reached a 1/2 amp of current. I am anodizing roughly 3/4 sq. ft. of t/6 aluminum. I use 3 rather large anodizing annodes spaced apart about 1/3 way around the bucket and about 7" deep which if added up comes to about 1.5 sq. ft. Material is spaced about 2" away from anodized metal. Am I doing this right? Am I just getting lucky? Is there a way of tweeting my pore size? My pore size seems rather small but dyes nicely. Thanks in advance for any advice.
Harry
