acid copper
Thanks for the reply. Since I posted the question I have built it up with copper and then sanded down. Seems like it's going to work. I am using the 25 amp rectifier for this with just the on switch and dial for the amps. Unless it has it's own resistor inside I don't use one. The 100 amp rectifier I use for the chrome where you need bigger amperages.
