Thread: Grounding
Old 08-31-2004, 04:03 PM
Noob2PC's Avatar
Noob2PC Noob2PC is offline
Noob2PC
Originally Posted by pdeinc
You just made me realize that either I should use 2 different hooks for each item or else I will be curing powder onto my hooks intended for spraying. That's not without its own set of problems, that is transferring the item from one hook to the other without shaking off some powder. Do you use the same hook?
Are you ready for this next storm? I'm in Melbourne and starting to plan my escape route.
I am staying put. to hell with running, where am going to run to? my closest relaitive is in Clairmont and then it is Hollywood
