Thanks for this - It does clear some things up a bit. I'll go and re-check things.
The single biggest part is 1.98 Sq Ft so I would still have a problem with power as I need 15A @ 6ASF roughly. I do have a line on a 50A psu which if I can make a VCCS circuit for would be perfect. Any help on that would be greatly appreciate!
I'll go back to the manual as well and see.
Would you suggest I try another test with a meter on right from the outset and see if it spikes and then drops right at the beginning? If the connection was killed - wouldn't the bubbles aroudn the part stop?
and to you and everyone else I REALLY appreciate your help - Thanks!
