Combined powder coat & anodize
This is a dual forum post, involving powder coating & anodizing. I’ve posted this on the Anodizing forum as well. Now that I’ve got these two figured out, it’s time to do some real parts.
I’ve got a cast aluminum part that has a steel part embedded. I’m planning to mask the steel (w/Caswell liquid Mask-It), anodize the aluminum, then mask the aluminum, and powder coat the steel. (or the other way around).
Is powder coat affected by an anodize bath? (25% sulfuric acid)
If so, I can mask it off, but then is the PC surface finish affected by the masking agent?
Best to PC first, or anodize first?
Does anyone see other problems with this?
Thanks, Sean
