  #19 (permalink)
Old 09-03-2004, 12:08 PM
neilfj neilfj is offline
neilfj
If you're using 98% sulfuric, there is a slight difference between % by weight and % by volume....but not enough to matter much.
You'd mix about 5 - 5.5 ml of acid to each 100ml of distilled water. This will give you a 4.8 - 5.2% final concentration, which is fine for LCD.
There are methods to determine this exactly, but its really not worth the effort as LCD has a wide range of concentrations in which it will work.
