Thread: pits in finish
Old 09-08-2004, 11:07 PM
customandsound
Guest
Posts: n/a
Originally Posted by allcarfan
if the pits are indeed a form of outgassing, you could try heating the metal first so it will outgas.
nope you only do that in coating . if you were powder coating . and you heated the part then shot the powder on and cured it the powder will get in to the nocks and crannys so it will seal it . not with polishing the bubbles in the metal are there . when you buff you take metal away to form a smooth look . metal has texture and when you start to remove the texture you get a better reflection from the item . kind of like removing a mountain to let the sun flow in the window briter ..
