Old 09-22-2002, 09:17 AM
rotorman rotorman is offline
rotorman
Default back to basics - annoying (long post)
OK, first of all, thanks to the creators of this forum. Polishing to me so far has been like a secret guild whose members do not want to let out any knowledge. Hopefully this\'ll change things.
I am a beginner. I have begun trying to polish metal in order to polish some parts of my car cheaply (and for a new hobby). I have recently bought a spindle attachment and two 6\" wheels for my bench grinder - one is stiched sisal, 1\" wide, the other is 2\" wide loose calico leaf. The parts I have in front of me are stainless steel from the looks of it.
Here is my problem:
I can get the part to mirror finish but on certain angles in bright light, scratches from the buffing are all over the surface - they are not deep - they are in the direction of the buffing and are near the surface.
I\'ll explain what I\'m doing in detail and maybe I\'m doing something really simple wrong. I couldn\'t find anything in the manual on this website. Maybe it is so simple it\'s not worth mentioning!
The surface is already flat (no scratches), so I used the sisal buff first with grey compound. I have cleaned the wheel with a screwdriver. I then applied the compound evenly. I have tried buffing by bringing the part to the edge of the wheel and keeping it still, rubbing it left-right, and moving it up/down - all are equally scratching. I don\'t know which one is correct! I am usually varying degrees of pressure - too much and it is bad, too little and it doesn\'t do anything. I have also tried wetting the part and keeping it dry. I just read that maybe I should be heating it up (it\'s cold here at the moment being in the southern hemishere). It is really scratchy but i can get some shine out of it.
Next, I use the loose calico buff with the green compound. This gives a really good mirror finish in all but bright light, but leaves scratches - finer ones than before (but does not get rid of the other scratches all together). Once again, I experimented as above, but also tried holding the workpiece stationary and moving it really slowly. Also tried varying pressures - the finish changes - but it is never satisfactory. I also tried going the opposite grain to the grey cutting - it just leaves scratches in the opposite direction.
My bench grinder is rated at 2850rpm, which according to this website is about right for a 6 inch wheel.
To sum up:
(1) should the buff be cleaned more aggressively?
(2) do the wheels need to be trimmed before use (ie with scissors or something)?
(3) where on the edge of the wheel should the piece be placed (ie on an angle at the very corner or flat against the edge)?
(4) what direction should it be moved (up/down/left/right)?
(5) what speed should it be moved at?
(6) does the workpiece need to be heated up?
(7) besides cleaning compound off, is any liquid necessary (like water on the workpiece when buffing)?
( should stainless when polished perfectly have scratches even if it is only on certain angles or am I just a perfectionist?
That\'s it...PLEASE hellp me!
