Old 09-10-2004, 07:23 AM
Gabourie Gabourie is offline
Gabourie
Default Power supply follow up question: Attention Fibergeek
I know we are all very busy, but I was wondering if you have had an opportunity to test any of the power supplies. I was encountering a small efficiency problem so I bought another power supply to be able to use more than one tank at a time. Well guess what? It is even more sensitive.
Having to use a resistor to get it to start, I have found that the voltage is now higher on the meter, will that effect the plating process? In the flash copper as well as Nickel, I can get the unit to start with the resistor then I take it out of the circuit and it stays on. It is like there is a threshold limit then once it is on the unit stays on? I have read many of the posting on this forum and I have not seen any that mention a start up "problem". I am getting use to using a resistor. I just wish there was a better way? Obviously this would not be something suggested , but could it be something as simple as adjusting a "pot" on the board to make it not as sensitive? Even though you get what you pay for, they are not that cheap.
