  #10 (permalink)
Old 09-22-2004, 06:27 PM
seanc seanc is offline
Zinc Plating Guru
Broke:
The person on the phone said that 65F to 90F is OK temps, and when asked if hotter was better, they said they would think so
This is for the blackener? I have never heard of trying to use it at higher temperatures. I've always just used it at ambient, most recently that has been @65º.
'm inclined to try 4:1 if you said it was working for you
Well it would seem now that 9:1 is correct, but consider this: perhaps the reason my blackener seems to stick better is because of the double-strength solution? I have no idea if this could be a contributing factor, but it can’t hurt to try at 4:1, since you can always add more water later to bring it up to 9:1
And another possibility: The suppliers directions recommending “water displacing” sealants has given me another thought. Since the “WD” in WD-40 means water-displacing, it occurs to me that letting the parts dry (as per instructions) before hitting them w/WD-40 is backwards (once dry, there’s no more W to D!). I’m going to try dropping my parts immediately into WD-40 and see if that helps.
Here's some pictures of my real parts:
http://www.hogheaven.com/hobby/plati.../ccparts1.html
