Old 10-12-2004, 08:15 AM
PeterM PeterM is offline
PeterM
Default Voltage movement
Hello
I took a long break in trying to learn the secrets of anodizing due to shortage of free time, but now im back with my newbie skills and questions
Today I did a new try.
*16 sq. inch part
*77mA
*Alloy: 60XX
*5% Acid solution
*I used a CC rectifier and amperemeters to log the voltage and ampere values.
*for cathode i used a 50 sq inch lead plate.
*For agitation i used a ceramic rod for fish tanks connected to a small airpump.
*Heating: had none to use
*For connections:
Titaniumwire strongly connected (hammered) into a screw-gizmo i made. To that i connected the cable from + of the rectifier with a scew and bolt.
Since i cant drill holes in my parts i had to use the very stiff titanium wire and bent it and slide it into the part, so that I ended up with 3 connection spots between the wire and the part (also this very very tight - though i know this could be the weak spot also in my run)
Run:
I prepped the part, did waterbreak test and so on. Connected it to the system and turned on the rectifier: My voltage immiedately started to raise...and fast.
After about 5 minutes i was up from 0V to 8V. Then it started raising slower, and after about 7 minutes i had 10.24V. Then..suddenly it started going down. After 25 minutes at 9.34V.
Now my question...shouldnt PAR-value be reached within approx 40 min using LCD method?
And why does my voltage first start to climb like it should, then suddenly so few minutes after start begin to go down?
Is this due to bad connection, or me not using heater to have a specific bath temperature?
Enlighten me metal finishing gurus!
//Peter
