You will need to use a electro stripping prosses.
Just get the stuff to make a pickle tank large enough to pip the rims into and apply the positive to the rim and negative to the anodes and I think you will need 1 AMP per square inch of rim, I think motorcycles rims are about 800 Sq. Inches so that would take allot of power unless you dipped in small parts one at a time? give it some thought and call caswell and ask if there is an easier way or one that does not need power to strip.
