  #10 (permalink)
Old 10-17-2004, 06:46 PM
getastro's Avatar
getastro getastro is offline
getastro
Thanks for the info. I wish I could add more elements, but I would max out the incomming power supply. I am running the oven on a 60 AMP breaker at this time and only have 100 AMP Main to my little shop. This is the reason thought about gas. Is 250K LP gas around the correct amount to run in this oven? If I run it with compressed air & gas mix this should cut down on the amount a gas used right?
