Gun spitting excess powder
When I did my first part using black magic powder, gun performed well and I got a satisfactory coating on the part. I did some experimenting with air pressure and techniques and found that with too much pressure, much of powder blew past the part, lower pressure allowed the powder to be attracted to the part.
Did my second part last night, clear coated an automotive water pump. Using what I thought was similar technique, I had the gun occasionally spew powder, sometimes when the trigger was first pulled, other times when I shifted the gun abruptly. By the time I got a satisfactory coating on the part, the gun had probably spilled more powder than was on the part.
Thinking about it later, I had two thoughts. One, how is the PC process affected by ambient humidity? I'm in Florida and it was raining last night, probably 99% humidity. Powder was fresh out of the can tho.
Second thought was that if air pressure is too low, powder can accumulate in the barrel. I may need a different setup on my tank with a low pressure regulator, possibly mounted to my spray booth to control that initial burst of air that I observed. I may be adjusting pressure based on the initial burst and the subsequent lower pressure is inadequate.
