  #28 (permalink)
Old 11-03-2004, 08:20 PM
wonbadmfer wonbadmfer is offline
wonbadmfer
Originally Posted by thekuai
ok i dont have a bench grinder nor do I have an air compressor. I think it is just overkill and heavy to buy a grinder to polish a motorcycle frame...so what kind of tool do you recommend to me? I have an 19v cordless drill but it only spins at 1350 rpm.....my motorcycle frame is made out of aluminum....what tool should i get? maybe an angle grinder? or how about those buffers you use to wax your car? any sugggestions?! thanks!
A uses to thick of wheel like wool is will clog fast, and if that buffer grabs that frame you will be hurting it is all about the speed of your wheels to fast an you will streak your aluminum or burn it to slow and it will be very dull
