Thread: ventilation
Old 11-12-2004, 10:02 AM
jtsuttle jtsuttle is offline
jtsuttle
Default ventilation
What do you guys use for ventilation? I am planning to build a new ventilation system so I thought I would get some input from you guys first. I have been using a small squirl cage fan but it is getting pretty corroded from the fumes off of my anodize tank, plus its way to small. I have looked for larger fans of the same type but most have the motor on the inside right in the path of the fumes. I would think that this is a bad idea. I would like a fan that is powerful enough to do 4 of my tanks at a time (anodize, 2 dyes, and sealer). The tanks are 18 gallons each. The fan I have now will only do one tank at best. I have modified the lids of my tanks to double as vent hoods so that each one has its own hood. They will be ducted to the exhaust fan via 4" pvc dryer vent hose. At the fan I will fabricate some sort of pvc atachment to accept the 4 hoses. My main question is what would be the best fan to use and where to find one. Any recommendations on CFM requirements and corrosion resistance would be greatly appreciated.
Later,
Jason
