Electroless is flexible and does not build up on edges. Correct? As opposed to electro-nickel.
What sort of thickness is required/recommended? 25-30 ? Would that represent approx an hour dip?
What size kit would I require for two barrels?
If the barrels are sealed up. any good tips for sinking them?
Or should I just pug bolt holes -nickel first and then bore them out to my spec.
Is thicker better? OR how would achive the best results for something that is to be ridden.
How do repair age cracks (expansion/contraction) or nicks (stone chips) properly.
Thank-you
Paul Edwards - thewebguy - AMCA
http://www.antiquemotorcycle.org
antique Harley-Davidson, Indian motocycles
