First time anodizing questions
I just finished anodizing the aluminum bar stock supplied with the deluxe kit from Caswell. I polished the bar and ran it through all of the steps as outlined in the manual including dying it black. I used the sput welder to make the connection (worked great) and decided to anodize the entire bar. Everything seems to have worked out fine. The aluminum bar looks fine.
I have a few basic questions one being when I did the calculations for the 10x1x.1/8inch bar I came out with a current factor of 700 milliamps. The manual said to use 1 amp. Did I miscalculate or are we talking about horse shoes, do you round off the number to the nearest whole number. I’m using a constant current power supply and I believe PAR was reached as the manual said at around 90 minutes.
I rigged up a simple agitator using ½” PVC pipe that I was able to place under the bar. Of course when the water is forced out of the pipe by the air, the agitator tends to float. Seeing as the GP plates that Caswell supplies are lead could I use small lead sinkers placed inside the pipe to weigh it down? I tried it out in a separate water tank and it worked.
I ‘m using the four 300 watt heaters that Caswell supplies to heat my tanks. I found that I was rinsing and moving them from tank to tank in order to get the required temperature in a reasonable amount of time. Is there a higher wattage heater I could purchase for use with the deluxe kit?
The anodizing sealant is made up with nickel acetate; the label warns that it could cause cancer. I’m using a chemical respirator during the boiling process but I’m still fearful of any remaining vapors. Would anodizing sealant LT be better and safer to use? Thanks again for your help.
