mkewl,
When curing powder, if the cure cycle required is 400 degrees for 10 minutes, that means that the PMT or part temperature needs to be at 400 degrees. Once the part reaches 400 degrees, then you would cure for a period of 10 minutes. You would need to have an infrared thermometer to determine the PMT.
Jim
