Hello! Not a plea for help this time
I've noticed that the plating manual doesn't really cover plating tiny, tiny things (~.5sq in) and I'd been having *alot* of trouble with it.
After trying everything in order, I found what worked. for this tiny part, I'm plating copper at nearly 2A per square inch! Why? Because at less than about .5-.7v, no copper moves at all. With this part in the bath at the recommended 25-50ma, the voltmeter reads about .2v. After a whole night of utterly failed 1 hour runs (which did nothing but turn the part in question a dark grey), I kept upping amperage until I hit one volt, the recommended minimum voltage.
Bingo. A *perfect* copper plate. Better, even, than I dreamed was possible. And in only ten minutes. Really stunning, mirror smooth copper. Wow. Wow. The ampmeter, at this point, read 1.2A.
Do any of the real gurus have a better very-small-parts voltage-amperage table to offer?
Monty
