anno power supply
I'm looking to set up a small anno line, and I'm wondering if I can use what I have already for a power supply. I have a 12-14 volt DC power supply rated at 12.5 amps. Yes, the amperage is a little on the low side, but I'm only going to be working with small items (Surface area would be around 50 square inches at the max, many of the items being less than 25). Would this work as a power supply? I've used this item as an alternative to a 12 volt battery in other applications, and I've read elsewhere that for small projects a 12 volt battery or two work as a power supply, so I'm going to assume that there is some potential in my 12 volt dc unit. If it is absolutely necessary I buy something else, well I guess I have no choice, but I'd like to save some money if I can (at least for the time being). Thanks.
