Hello,
You shouldn't have to touch your copy chrome solution with one exception. If it starts plating a little dull, you add 2 ounces per gallon of brightener, but ONLY when it starts plating dull.
What is more likely happening to you is your hanger wires or bar are getting corroded. Are you measuring a current while the part is in the solution?
Kind regards,
Ken
