Our supplier specifies this heat as optimum.
NAPA acid = prod # 9002 Try any battery supplier.
Sealing in the dye isn't in the procedure. You could try it - but don't complain if it doesn't work.
Airbrushing will result in the possibility of a weaker color. You may need to increase the concentration to counter this.
