As long as the flashing is not made or lead? It should be ok, as long as you plan to insulate, although a little thin & you do not plan to hang items from the flashing. Might want to skin the outside with fire rated sheetrock, if the structure is framed with metal studs it should be OK?
Bob
www.capecodpowdercoating.com
