Old 01-14-2005, 11:23 AM
wolfpline wolfpline is offline
wolfpline
Default Blast Cabinet
Just an idea; since a blasting cabinet is best if sealed and the media is in a close-loop system, why not just get a chest Freezer. They are in the paper FREE all the time if you and a friend go move it. Once at home knock 2 or 4 glove holes in it, a nice long viewing window, air attachments, and some tension clasp locks to hold the top shut and your done? Right? Parts load in from the top. You could even make a rack to hold them off the bottom and put in a trap door for abrasive removal. Then if you want to get real industrious, find an ATV lift in the classifieds ($30-$50) and you can raise and lower the thing with an air to load heavier parts into it. Even from an ergonomics standpoint you can custom adjust the height to anyone using the cabinet. No more stooping to see in resulting in a sore back. Any thoughts?
