Old 01-15-2005, 07:30 PM
DALE DALE is offline
Do you already have the powdering equipment? If yes then have your friend paint a scrap test peice and see if it will take the heat.If the paint doesn't fail the heat test then powder it and check again. There are many chemistries of paint on the market so it is usually best to test with the actual materials you intend to use. With the test and see method you can insure that you are getting exactly what you want.
