Old 01-17-2005, 12:05 AM
Pearl-Jam Pearl-Jam is offline
Pearl-Jam
Default Need help with Iron Phosphate wash
Hello Crew,
My questions are this:
Can someone give me a few suggestions on the iron phosphate process.
I want to do this to a steel frame prior to powder coating. Are there
any low temp phosphate solutions ( I would spray it on ) just for powder coating out on the market and where can I buy them ? ( Names, web sight or phone number )
How about two stage phosphate wash, Coat and D.I. rinse ?
Is de-ionized water as good, not as good or better than distilled water to use as a rinse?
I went to the local Sherwin - Williams paint store and told them what I wanted to do. I was sold a product made by Jasco. Its their Prep and Primer that leaves behind a iron phosphate finish. This appears to be a no - rinse solution ( I tried doing a light D.I. water rinse and the part flash rusted in ten min. ) and I don't know if this product can be used for powder coating. Seems the sales people at the store didn't have the answers I needed to my questions.
What would some of you guys and gals do if you wanted to prep
( iron phosphate ) a steel frame prior to powder coating ?
I have been using Eastwood products for the past two years and the item had to be bare clean metal to powder coat. The item will still be bare clean metal to start the iron phosphate phase. This is a new process for me, and with your help, I would like to get it right.
"If you check out my photo galley on this web sight, you will find a quad frame powder coating jig I made that might interest you."
Thanks ,
Drew Young
Bronco69302@hotmail.com
