that glass jar incloser sounds like a idea worth looking into. i was wondering would a hot water heater element work for that? what we have ordered now is a (l) shaped heater to heat from the bottem up with a 90 degree angle on the top end out side the tank. this will i hope stop the condensation in the top of the heaters and keep the sand dry. but the idea of the glass jar sounds a whole lot cheaper. what would you recommend for sealing the inlet to the jar? thanks clydes
