Old 01-25-2005, 09:50 AM
jackf jackf is offline
jackf
Default Nickel bath inexplicably quits plating
I have had my Nickel electrolytic bath go bad twice.. I plate only steel, brass, or copperplate. The problem starts out abruptly with black streaks appearing on the work.These seem to be rising vertically from the lower levels of the tank, as though some stratification has taken place. Shortly thereafter the solution stops plating. I have tried heavy plating on iron sheets to clean up the tank, but even with enormous currents plating is very skimpy or nonexistent. It seems strange that the ion bonds aren't broken with amperes of current, when normal plating takes only a few milliamperes. The ph I measure with a plant type ph meter runs 6 to 7, very acid.
I tried adding brightener but that was no help. I have to start a new tank each time. That works well for a year or two, then suddenly toggles over into this shocking condition.
The process I have worked out is to sandblast or polish the metal, Degrease it thoroughly with carbureter cleaner and rinse in near boiing water, pickle it for a few seconds in dilute Hydrochloric acid, rinse in flowing hot water and immediately put it into the plating tank with the current adjusted for approximately 25 ma per square inch of work surface. I normally allow 2 hours for a useful cosmetic plating and four hours for a hard work surface on tools.
any ideas? Thanks Jack.
