Old 01-26-2005, 05:49 PM
Pearl-Jam Pearl-Jam is offline
Pearl-Jam
That's a small air compressor motor if your planning on doing any type of media blasting. Its not so much your tank size you have to consider , its what you have as a constant running pressure. My compressor can maintain 110 psi running pressure with the motor on and the line in use before it kicks off in about 10 min. after filling my tank . That's about a $2500.00 air compressor. Tank size is only good if you have the motor to fill it back up. I would not go much below 90 psi running pressure to media blast anything of size. If you can , wire your compressor for 220v. That's only if it says so in the directions for direct wire. The motor will love you for it and you will save $ on electric because the motor will not have to work so hard. Hope this helps,
Drew Young
Today's mighty oak was just some nut that held it's ground !
