Newbie ? on copychome and flash copper?
OK, I have been reading and studying, but have a couple of questions.
I have to replate chromed steel seatbelt tongues and buckles. The tongues have varying degrees of rust and pitting. The buckles have a little rust as well as fine line words. I will be glassbeading the rust.
1. Will I have to still use the acid dip to remove the chrome and nickel coats?
2. Can I use the flash copper to provide the base and then solder pits then a final coat of flash copper?
3. Can I then use the copychrome?
4. Will Copy Chrome hold up under normal (classic car) seatbelt use?
5. Will the flash copper and Copy Chrome fill the fine etched wording? (hopefully not)
Last but not least, Can Copy Chrome be NOT buffed for a satin look? Maybe glass beading the copper prior to the Copy Chrome might give it the look.
Sorry for all the questions at once, but I'm trying to figure out what type of kit to buy. I.E. 2 gal triple Chrome or less expensive flash copper and copy chrome.
Thanks, Kevin
