Old 02-13-2005, 01:55 PM
Sid03 Sid03 is offline
Sid03
Default etch....desmut.....deoxidize.........weeeeeeeeeeee eee
Im currently using the following prep steps....
* SP cleaner @ 140degrees- varied times
* Desmut/deoxidizer @ 110degrees- 1 minute
What im wondering is should I add an etch step, or should the caswells desmut/deoxidizer take care of any oxide buildup on the aluminum(in the case the parts have sat around awhile after polishing/bead blasting)?
Thanks
