OK, it turns out the Metalbrite is mainly phosphoric acid, with some hydrogen flouride and a surfactant thrown in. I guess I need to know if that will strip previously anodized items.
I plan on farming out the cleaning side to a local bead-blaster, so I won't be using a dedicated chemical stripper either. I might end up using a product called Carbon Off, which is Phenol and Methylene Chloride, with some detergent, corrosion inhibitor and water thrown in.
I'll invest in a manual, the more you read, the better!
Thanks for all the info,
Simon
