Re: another oven question
Hi Corey:
Your second element may not be bad? Do you have it wired in a series (jumping from one element to the other)? I f so, you may want to change that. Although you can have 2 wired off the same thermostat, you must wire them each directly to the stat.
As for the fan... it helps make the heat more stable thru out the oven space (no hot or cold spots).
Good Luck
Bob
