Thanks for your reply trsick. Do you think putting them in the floor would be ok? Or putting them on the side walls make better sense? I should use 6 elements ? How many amps would that pull?Let's see if I can remember. Amps x Volts =Watts,so watts divided by volts =amps. I think thats right? So 3100watts x6=18300w,so 18300 divided by 240v=76.25amps. Thats alot of amps to pull in a garage. Does that sound right to you?Any suggestions? Thanks for your help.
