Thread: Rinse Methods
Old 04-03-2005, 12:49 AM
acidrain acidrain is offline
Be careful of the sprayers you get at the garden stores... they are packed with grease at the seals.
Check that they can be disassembled and cleaned before purchasing.
I rinse with distilled water spray (each step) paying special attention to areas that can trap the solution (each rince is allowed to drain into the solution tank). After rinsing, I submerge the parts in in fresh distilled water.
After ano, same thing except after the rinse, a quick dunk in the neutralizer tank (as precision PB suggests), then the distilled water tank.
I go through lots of distilled water! I should buy a reverse osmosis setup.
