Old 04-13-2005, 12:45 AM
customandsound
Guest
Posts: n/a
you can put the part in a oven and set it at clean 800F this should aid in the removal by baking it off. to prep after coated . I use a sharp oxide ot steel to remove it. it is best to remove if you have alot of defects in the coating .
Good luck. and happy powdering :'
Chuck
