Old 05-03-2005, 11:45 PM
nicanor76 nicanor76 is offline
nicanor76
Default plating only some (unremoveable) parts off a bigger item
I'm about to invest a a nickel plating setup, basically will be making custom steering wheels (and sometimes restoring some). I only want the center spokes plated (metal) but it won't always be possible to seperate that part away from the rest of the steeering wheel. Would there be any issues if I dip the entire steering wheel (center hub, rim, resin around the rim and all) just to plate the spokes? Not sure if you're only suppose to dip the item to be plated and nothing else or..?? Thanks
Pict below should help with what I'm talking about
