I use TLHB. It's great if you're trying to prevent blueing of your chrome pipes. The easiest way to use it is to soak a sponge with it and pull it through the tubes while adding more TLHB as you go down the pipe. Let it sit till it gets tacky and bake it. TLHB is solvent based so you need to apply it in a VERY WELL ventilated area. For a single pipe I just cork one end of the pipe and pour some TLHB into the pipe, cork the other end and shake and twist the pipe around for a while till all the liquid is used up and uncork it to let it dry. It is baked for 60 mins @ 300f.
