Old 05-18-2005, 12:37 PM
fxstcguy98 fxstcguy98 is offline
After passing water break, go directly into zincate if it begins to fizz, leave it in for only about 10 to 15 sec after the fizzing starts. The uniform dull grey color is normal. Rinse well and go immediately into the strike bath (flash copper or nickle) and go into the bath with the power on at about .13amps/sqin for 30 sec to 60 sec and then drop the amps back to .06amps/sqin for rest of the strike cycle (about 10 min). The bath will dissolve the zincate and if you have brighteners (nickle) in the bath, it should come out shiny. If you plan on doing a lot of alum., you should consider using flash copper and buffing afterwards (and before), because over time, the zinc will contaminate your nickle bath. Hope this helps.
Darrin
