Old 05-18-2005, 01:26 PM
clydes clydes is offline
clydes is an unknown quantity at this point
ok this is what works for me . put the part in the chrome stripper for about 10 to 15 min with about 50 amps on it. this will take off the chrome and some nickel. the longer you leave it the more nickel it will remove check it often. then blasting is easy saves tons of time. its just my way of doing it so try it if you want. good luck( better to use a high ph than a low on pot metal)
