Old 05-20-2005, 06:44 PM
mpierich mpierich is offline
Default Re: transmission casing
Originally Posted by berndog
I'm polishing a turbo 350 trans,,,I glass blasted it first,,any ideas how I can get into nooks and crannies?I'm using electric handheld polisher & air die grinder
For initial grinding, cartridge rolls (tapered and straight) in the die grinder. If the grinder or Dremel is variable speed, can use felt bob with greaseless or (preferably) felt bob or mini-wheel with setup glue/abrasive. Too high a speed will throw the greaseless or setup glue off. Wear eye protection.
Polish with bobs and mini-wheels and emery. With proper grinding grits that might be enough.
