Old 06-03-2005, 04:21 PM
fxstcguy98 fxstcguy98 is offline
I believe pickle #1 (muratic) will remove the chrome, you make have to use the lead GP plates using pos on the club and neg on the GP. Use pickle #3 (sulfuric) to remove the nickle using the same method. If the nickle is in good condition, you could just activate the nickle with a 15 to 30 second dip in the pickle#3, rinse and either rechrome it or go straight to flash copper then nickle. I'm not sure if you can activate the nickle and nickle plate it directly or not, but the flash copper will stick to the nickle just as well as it does carbon steel.
